lindsayt
Benedict, I don't know about passive bi-amping. I've never done it.
However I am listening to an actively bi-amped system now.
I don't know about your speakers. But all of my speakers have more efficient drivers for the upper frequencies than they do for the lower frequencies. IE in all of my speakers the tweeters need less power than the midrange units to achieve the same measured sound volume. The midrange units require less power than the bass units to achieve the same volumes.
With my speakers a relatively flat frequency response is maintaned when used in passive mode by a combination of the lower frequency units having a lower nominal impedance (and therefore sucking more power from the amps) combined with the upper frequency drivers being padded down (resistors used as a simple volume attenuator).
As well as the efficiency there's also damping factor requirements. At higher volumes bass cones will move in and out. In extreme cases this movement is visible. Midrange units and tweeters never move in and out to anywhere near the same extent. This means that bass cones generally benefit by being powered by amps with a high damping factor. In general, on average, the amps with the highest damping factors tend to be the most powerful ones.
Also, check out a few frequency spectrum charts. You'll see that pop and rock music has significantly more content below 1 khz than above.
All of which adds up to me always using my most powerful amps for the bass and my least powerful for the midrange / treble.
