Hello and thanks for having a read.
I have two problems that you could perhaps help me understand.My system is a 90's Technics 1060 model, I was listening to some Neil Young a few weeks ago before heading off to see him live and all was good. The next day I go to play the same tracks and the sound from both original 1060 speakers sounded dull / clouded / muffled / and there is no sound at all coming through the tweeters?Keeping in mind electronics is not my strong point I took the speakers to bits and everything looked OK but still sounded rubbish.So I hooked up a pair of old B&O speakers, unmatched to the amp (100w 6 Ohm amp v 30W 8 Ohm speakers), but they are keeping the sounds coming for now.What has happened? And while I was hunting for the replacement speakers I found an old Yamaha JA 1801 woofer cone stashed away and I'm sure it used to work but now it wont make a sound at all when hooked up to the Technics amp.I mean Neil Young is still playing so its not the end of the world and I had a bit of Band Of Skulls blasting tonight but I would love to fix these speakers.If you can help out then thanks for any advice or banter.Cheers,jp
