Tannoy Revolution XT6F dimensions
torikoos
9
Hi there,
Anyone here own a pair of these? I would like to know how wide these are. It seems mostly the dimensions given include the plinth. I'd like to know how wide the actual speakers are?
Also , although not entirely obvious from the majority of pictures, it appears this speaker is slightly narrower at the rear. Anyone have a good top view picture? How wide is it at the rear? Just to get an idea.
Also how does Tannoy's 'dual concentric' driver compare to KEF's similar solution called UniQ. Pro's and cons of each?
Many thanks!
torikoos said:
Hi there,
Many thanks!
1005 x 269 x 317mm
Thank you, but arent' those the plinth dimensions? The plinth is wider than the actual speaker column. I wanted to know what the speaker column width is? Or is the plinth even wider?
Speaker only
OK thanks for confirming that, It appears the Tannoy's are out. they are too wide for me, I can't fit them properly where I need them.
