Hello every One,
I need some expert advice. I am not looking to buy any of these speakers for now. But would Love to understand the difference between them.Exept the build quality of the cabitnet and over all weight. All drivers are same, crossover is same. here and there on some numbers and over all weight.
Why should one pay 1700 for the same tech that is on 1000 and if you are paying for looks i understand but there should not be a difference in performance. I know both are five stars and well reveiwed.
But i beleive the reveiw should be the same....
Have a look.
Tannoy Revolution DC 6T SE 1000 Pounds.
PERFORMANCE
Recommended amplifier power (Watts RMS)
20 – 200
Continuous power handling
(Watts Peak RMS)
100
Peak power handling (Watts)
400
Sensitivity (2.83 Volts @ 1m)
90 dB
Nominal Impedance (Ohms)
8
Frequency response (-6dB)
30 Hz – 35 kHz
Dispersion (degrees conical)
90
DRIVE UNITS
Dual Concentric™ high frequency
25 mm (1”) Titanium dome with Tulip WaveGuide™
Dual Concentric™ low frequency
150 mm (6”) treated paper pulp cone with rubber surround.
44 mm (1.75”) edge wound voice coil.
Bass Driver
44 mm (1.75”) wound voice coil.
CROSSOVER
Crossover Frequency
1.7 kHz
Crossover Type
Passive low loss 2nd order LF, 1st order HF
CABINET
Enclosure type
Rear ported
Construction
15 mm particle board, internally cross-braced enclosure
18 mm MDF front baffle
Dimensions (inc. plinth and grille)
950 x 256 x 292 mm (37.40 x 10.09 x 11.50")
Volume - litres (cubic feet)
29.6 L (1.045 cu. ft.)
Weight
16.4kg (36.1 lbs)
Finish
Espresso
Precision 6.2
PERFORMANCE
20 – 175
(Watts Peak RMS)
87
350
89 dB
8
34 Hz – 35 kHz
90
DRIVE UNITS
150 mm (6”) treated paper pulp cone with rubber surround. 44 mm (1.75”) edge-wound voice coil
Bass Driver
CROSSOVER
Crossover Frequency
170 Hz, 1.6 kHz
Crossover Type
CABINET
Enclosure type
Rear ported
Dimensions (excl grille) H x W x D
1000 x 310 x 283 mm (39.4 x 12.2 x 11.14”)
29.3 Litres (1.03 cu. ft.)
Weight
18.4 kg (40.6 lbs)
Finish
Satin dark walnut
High gloss dark walnut
High gloss black
Have a look.
PERFORMANCE
20 – 200
(Watts Peak RMS)
100
400
90 dB
8
30 Hz – 35 kHz
90
DRIVE UNITS
Bass Driver
CROSSOVER
Crossover Frequency
1.7 kHz
Crossover Type
CABINET
Enclosure type
Rear ported
Construction
Weight
16.4kg (36.1 lbs)
Finish
Espresso
Precision 6.2
PERFORMANCE
20 – 175
(Watts Peak RMS)
87
350
89 dB
8
34 Hz – 35 kHz
90
DRIVE UNITS
Bass Driver
CROSSOVER
Crossover Frequency
170 Hz, 1.6 kHz
Crossover Type
CABINET
Enclosure type
Rear ported
Weight
18.4 kg (40.6 lbs)
Finish
Satin dark walnut
High gloss black
