Systemdeck IIX
UKAudiophile
6
Can anyone recommend a supplier for the correct replacement belt and service components. My turntable has sat idle for 15+ years. I want to breath new life into it.
Thanks in advance
Can anyone recommend a supplier for the correct replacement belt and service with components. My turntable has sat idle for 15+ years. I want to breath new life into it.
Thanks in advance
Belts still available I believe. Any dealer that sells turntables should be able to service the bits that need looking at, you could do it yourself with a manual and some fresh bearing oil.
Well worth doing as they were great decks.
Reactions: UKAudiophile
