Hello!
First of all, I'd like to congratulate for this website and forum, I'm getting lots of useful info from them.
Of course, this is the umpteenth request for an advice. What a surprise, uh?
Please let me give you a little background.
I was (actually, still am) the happy owner of a JVC JL-A40. It was my late father-in-law turntable so me and my wife also had some sort of emotional attachment to it.
About two years ago, I've started having problem.
Each time I turned on my Piooner SX-750 (also belonged to my late father-in-law), I heard a huge rumble and all the lights flashed for a few seconds (up to 1 minute). Also, I kept hearing some very low rustle on the left channel.
I called a technician, he took my very heavy amplifier to his lab, brought it back and everything was fine for a week, then it started again.
I have to say that this happened only when I switched to phono.
Since then, the amplifier went back and forth from his lab 5 times. Once he tried to disconnect the internal power and use an external box, but I was told it would change the sound so I asked him to revert to internal power. That wasn't the issue, anyway.
Also, the last 2 times he said that in his lab he noticed no issue (which is something quite common for me with any kind of machine, I have to say).
I've tried to pass the signal from the phono to the amplifier through an external pre-amp, using the AUX input, and it occurred to me that the issue might have been in the turntable, since the rustle was still there (switching to AUX with no input made no noise at all). I forgot to say that the turntable has always been properly grounded.
Anyway, I was there congratulating with myself for the great discovery, when the turntable started accelerating. WAY over 78rpm (which is a speed the turntable didn't have, anyway) and didn't stop accelerating until I switched off the socket. I risked being decapitated by "Saturday Night Fever", what an inglorious end. If I knew it was going to happen, at least I would have put on "Foxtrot" by Genesis.
I don't really think it's worth repairing it, sentimental value aside, so I'd like to know if you can suggest something.
Here's what I'm looking for.
First of all, I live in the East Midlands (near Nottingham) so it should be something that I can buy on physical stores nearby or on Amazon or Ebay.
My budget is about 350 pounds (I know it's not much) and I'm willing to consider either new and used (if in optimal conditions).
I've read nice reviews of Rega Planar 3, but honestly I don't really like the idea of having to lift the platter and manually change the position of the belt each time I want to change speed (and I'm also worried that it's going to stretch after a few times).
Also, I'd like to have at least a semi-automatic record player so I don't risk to force the arm at the end of the record.
I'm open to change arm/pickup/cartridge in the future, but if the player comes with at least a good set it would be better so I could use all my budget for the turntable.
Obviously, because of the aforementioned budget, I don't expect any hi-end. I just need a decent machine to play my collection (mostly classic rock, jazz, some 80s pop and classical).
I'm not interested in USB ports and Bluetooth, I don't need to transfer my records on PC. Also, I don't need an integrated pre-amp.
Thank you so much for your patience reading all of this (I'm sorry if my English isn't good enough, I'm Italian) and for your help.
Best regards,
Fabio
Best regards,
Fabio
