Subwoofer - Velodyne SPL1200Ultra Vs Monitor Audio GX-15
umbucker
133
Which of these should I get - roughly the same price
Running with Pioneer SC-LX85. Tannoy Revolution Signature DC6T, DC6 Centre, DC4 rears. In a room 20' x 11'
CnoEvil
556
14
I see this decision is still occupying your mind. :)
I have a soft spot for Velodyne as stated here (along with other suggestions):
http://www.whathifi.com/forum/home-cinema/is-the-velodyne-spl-1200-ultra-a-good-match-with-tannoy-signature-revolution-dc6t
Though to be fair, I haven't heard the MA GX-15.
CnoEvil
556
14
KiwiMoto said:
Has anyone heard both the 1000 ultra and 1200 ultra?
Hi KM,
I heard the previous series (SPL 800R/1000R/1200R), which shouldn't be far away and the incremental improvement should be the same.
The 800R was the best small sub I'd ever heard, until the Paradigm Seismic 110 arrived.
IMO. There was a noticeable step up to the 1000, but when I compared it with the 1200R, I thought the difference was worth the extra, in a room 14' x 22' x 11' (I think it was around £200 more).
I see you own the 1000 ultra, and I'm not sure it would be worth the hit to change, especially as the Ultra series is a good bit more expensive. This is just my opinion, so you would have to hear the difference for yourself and see if the cost to change is worth the extra performance you will get.
KiwiMoto
55
My room is roughly 4m x 5.5m x 2.7m high.I thought the SPL1200 might be overkill?I'm going to place the 1000 about 1/2 way along the RHS 5.5m wall.
CnoEvil
556
14
FWIW. I think the SPL 1000 is plenty in that room, and the EQ system allows you to put it anywhere (even in a corner, as in my case).
umbucker
133
my room is slightly bigger than the above, I was looking at the SPL1000 but see the 1200 goes that bit lower in its frequency range. I am willing to pay that bit more for deeper tones, will this be noticable from the 10" driver up to the 12" ?
Frank Harvey
567
One of our customers recently swapped out his SVS cylinder for a GXW15, saying that while it didn't go as low, it did more of what he wanted from a sub. Maybe that was down to it's sealed cabinet or it's on board EQ, we don't know, but that was his choice after demoing the GXW15 at home directly against the SVS. I haven't heard the Velo, so I can't comment there.
