Subwoofer help
gasolin
Have bought a used active Jamo sub 200 (i am waiting for it to arrive).
I have a dali zensor 1 and a Denon DRA-F109, i have been told that my dali's will get full frequency without cutoff of the deepest bas, so i would like to know about a crossover for my subwoofer (40-150hz) my dali's are on speaker stands so they are not wall mounted and therefore don't have the extra bass i will have when it's wall mounted.
I need about 2.5-3.0 meter subwoofer interconnect, i live in denmark so it may not be all cables that you would recommend me that i can get in denmark.
What interconnect for my subwoofer would you recomend me? Max prices up to 21£ or 25€ (just give me your recommendation for a cheap but good interconnect, even if it's not something i can get in denmark)
Joshuamessenger
11
I would adjust the sub to 60hz so it will lift the bottom end of the Dali and bring it down to around 30hz. With volume around 45/55% on subwoofer amp. The idea is to blend sub seamlessly to the speakers
