How much better is the M compared to the ELS ?
It seems to have the same spec but with a wood veneer finish and a down firing driver as opposed to a front firing one
The power and driver size etc is the same as the ELS and Epos don't mention any specific internal improvements over the ELS
What would you say is better about the M sound wise compared to the ELS ?
Here are the spec differences of the ELS and Gemini:
ELS: 10" forward firing driver, 300w power, 20kg weight, 25mm MDF construction and seperately sealed amp in cabinet, 20Hz low frequency but don't know if at -3 or -6db, 75mm voice coil
Gemini: 8" down firing driver, 150w power, 12.5kg weight, 18mm MDF construction and 25Hz low frequency at -3db, 50mm voice coil
Any thoughts based on the specs ?
