Subwoofer Cable
Dermondo
132
Hi, at the moment I have a budget cable connected to my subwoofer, a monster cable in fact, but have been itching to upgrade this cable, so question is in this part of a set up can a different cable make any different to the sound ????, many thanks in advance.
Sliced Bread
510
93
18,970
They do make a difference, but you may find it less noticable than say standard interconnects between source and amplifier.
I upgraded from Monster to QED signature subwoofer cable and noticed a tightening of the bass, but the difference was quite small.
krish123
59
i agree witrh sliced bread, i recently changed my subwoofer cable to qed performance subwoofer cable. the bass now seems more musical and deep, and slightly tighter too, but again the differences are subtle.
can i just ask, does the cable to the subwoofer have to be a specific subwoofer cable or can you use a long interconnect?
Crossie
58
You can use a long interconnect. I agree with the other replies that any improvement will be very subtle if at all. I suggest you save your money and put it towards some new speakers and electronics where the upgrade will probably be more apparent.
songox
9
Hey! I changed my subs freebe cable to chord cobra a while back now and i can say there was only a minor improvement but recently i bought wireworld stratus 52 mains cable and there was a realy big imrpovement, sub can now go louder, feels deeper, tighter! I know its prety expensive but it could realy put a smile on your face! ;)
