Pistol Pete1:MUSICRAFT:Pistol Pete1:MUSICRAFT:
Hi giggsy1977
I would highly recommend the QED sub cables as i have sold hundreds of them over the years. I have not found their sub cables to be lean at all. If you can accomodate them than the ones to consider are Performance and especially the superb Reference or fantastic Signature sub cables.
Rick @ Musicraft
Rick,
How much do these kinda cable really differ when compared on the same machine?
We talking subtle, or 'night and day' differences? I have the old QED Qunex P-SW and was considering the QED Reference/Chord Cobra 3 upgrade?
Hi Pistol Pete1
The QED Performance is very good however the Reference justifies the extra premium in looks/build and performance. The QED Reference sub cable is what i am presently using to connect the Yamaha DSP-Z11 to the various ATC, Dynaudio and Monitor Audio subs that i stock. It has worked/performed admirably so therefore i would say that you can buy the Reference sub cable with confidence.
Btw, i will in due course upgrade permantely to the QED Signature sub cable. The Signature sub cable looks and sounds wicked!
If your budget allows than go for it. Truly superb. Well done QED.
All the best
Rick @ Musicraft
Thanks for your comments Rick, but you didn't really answer all my questions. I asked how the more expensive cables change the sound? Deeper bass, tighter bass, or what? And is the difference very obvious or subtle?
Pete
Hi Pistol Pete1
Fair enough. When using the DSP-Z11 and the PLW-15 the QED Reference sub cable does offer deeper and tighter bass when compared to the performance sub cable. Likewise the Signature sub cable offers an even tighter and punchier bass when compared to the Reference sub cable (again using the DSP-Z11 and PLW-15) although the difference is not as big as is between the Reference and Performance sub cables.
As it is also involved in the overall cost the looks, build, fit, finish, packaging of the Reference sub cable compared to the Performance and the Signature sub cable compared to the Reference sub cable is improved which i believe also justifies the extra cost.
All the best
Rick @ Musicraft
