SUB Cable for KEF 3005SE
Hi please could you recommend a sub cable for my kef 3005se package. At the moment I am using a long RCA svideo cable (puresonic I think), will a dedicated sub cable make any differences? The most I want to spend is about £40.
try mark grant cables excellent product and cheap as well, check out his b-products,just bought 6 metre sub lead in b-product sections mark on outer cable but i can`t find no mark
Fisty1967
Hi jpfreestyler
I bought the XED Performance Subwoofer cable from here .
I use it to connect my KEF3005's to my Yamaha DSP-AX863SE amp.
Reasonable price (£26.99 for 3m).
Sounds very good. Certainly a lot better than the generic cable i used before.
