Hello,
Right where do i start.
I have just brought some B&W CM8 with the CM range center speaker with a Pioneer sc-lx73 running it all.
Now I have a little money saved i need to invest in some rear speakers and a sub.
This is where i get confused (newbie). I have been thinking about getting the ASW10CM but at £900 is top end of budget
now considering what i have is it worth just drinking a can of man the F%£k up and just buying the Asw10cm and sticking with the CM? Or shall I go for a 610xp? Or another option i have been told was try the company REL either a T5 or the R218. I have done some looking into this but I'm still not sure what to go for.
Also i need some rear speakers and was also looking to keep within the CM range and go for the CM1 but then i got thinking these speakers are just rear speaker and would only get the odd sound coming from them. Now am i just being stupid or could i save a little and get something else. without making the system rubbish I don't want to scrimp too much on quality.
I don't want to sound like a tight ass just looking at other ways to save a little so i can spend on something else.
Any suggestion Good or Bad welcome.
Many thanks Lewis
Many thanks Lewis
