What exactly is the issue? Do I take it the Marantz 6005 doesn't support Qobuz?
I think this may be necessary but perhaps someone more knowledgeable will be along to answer shortly.yes think I probably need to subscribe to Audirvana , but unsure if this would make any difference
No, the Airplay function only allows Qobuz to be used in CD quality because of Airplays' restriction to 16 bit at 48kHzAirplay, so is there a way of achieving hi res then?? I
I am not sure, let's see if someone who knows a bit more about streaming than I do can help.do you think audirvana or changing to tidal wd b a better option?
The limitation is Airplay (or Bluetooth if you use that) so it doesn’t matter whether it’s Qobuz or Tidal you’re streaming from your iPhone you won’t output Hi Res without wires.I am not sure, let's see if someone who knows a bit more about streaming than I do can help.
Yes. See this article . I have the Marantz AV8805. I'm using a Mac laptop (you could use Windows) and the Linn Kazoo player. You get full resolution. I could NEVER find any way to do that with Tidal.I would like to stream qobuz through my iPhone 11 to marantz na 6005 media player, marantz pm amp and Bose speakers but have been unable to get his res quality. Any advice?
