- Aug 10, 2019
- 2,556
- 5
- 0
I have for home:
For uni:
To explain the two setups, I have the Tannoys so I can take the system to and from Uni and leave my Bi-wired Linns behind.
I have not had a chance to listen to the Tannoys with the setup but I thought I'd mention them, my birthday is in November and I need help choosing between upgrading the Amp or getting a Sub Woofer. Although the spectrum from the Linn Komponent 110 is awesome I feel that it lacks the most defenition at the longer wavelengths/lower frequencys, I do physics so please excuse me in the fact that I don't know which terms are used in the hi-fi comunity (if someone could just tell me what to use as part of their post I'd appreciate it).
Would I gain more from getting a dedicated sub-woofer or upgrading the Amp, which is the lowest spec (bar the tannoys) component in the system. Or as an amateur Hi-Fi ist, is there another upgrade path I have missed?
Thanks lots,
Charles
- Speakers: Linn Komponent 110
- Amplifier: Marantz PM7001
- CD player: Cyrus CD 8 x
- Cables: 4x 2m Chord Carnival Silver Screen Speaker Cable with QED Airloc 4mm Banana Plug
For uni:
- Speakers: Tannoy Mercury F1 Custom
- Cables: 2x 2m Chord Carnival Silver Screen Speaker Cable with QED Airloc 4mm Banana Plug
Thanks lots,
Charles
