- Mar 16, 2011
- 11
- 0
- 0
I recently acquired 24 feet of QED XTube-400 for a very good price. However it isn terminated. I purchased a set of 4 of the QED screw lock banana plugs however the diameter of the screwlock is 4mm while the cable is 6mm? Does anyone have experience with this cable? Are you meant to cut out the "airtube" in the middle of this cable so that it fits in the banana plugs? Or Are you meant to purchase a wider diameter banana plug? Does anyone have experience with these? http://www.qed-cable-shop.co.uk/product_info.php?products_id=405{2}46 It says they have 8mm diameter. If I buy the larger diameter "airloc" plugs, can I terminate them at home Hope someone can help
