step down converters for nakachimi 9.2.4 soundbar
johnny156
13
hi does the nakachimi 9.2.4 subwoofers need to be plugged in to wall sockets
do i need 3 wall sockets in total
i live in the united kingdom i bought from usa
if the subwoofer need plugs
what step down converters will i need three of them can you give me make and model
step down converters to use with the nakachimi 9.2.4 schockwave system thanks
johnny156
13
required soundbar 100-240 volt 50/60hz
Subwoofers 110-240 volts 50/60hz
Total soundbar wattage 1000 watts
what do you recommend to use with it
Most items either use US or EU voltages, the former is typically quoted as 110/120v and the latter 220v. The UK is 230/240v. EU and UK are compatible (plugs aside), but US isn't compatible with either. If your gear states it will cope with anything from 110-240v, it must have circuitry able to ascertain what voltage it is receiving and adjust accordingly - which would be a new one for me. Not that that would be saying much...
johnny156
13
would this do the trick LVYUAN 1000W 220V - 110V Step Up & Step Down Voltage Transformer Converter UK to US & US to UK Dual 110V & 220V outlets from amazon uk
johnny156
13
the trouble is I'm in the uk
it's American device
the soundbar power cable has 2 prongs
the subwoofer power cables has 2 prongs
so in the UK I need a converter trouble is which one to use
abacus
If the cables are detachable then have a look on Amazon for one that has a UK plug on the end instead of a US one.
You can also get UK to US adaptors from Amazon if you want to use the cable you have already got.
Use dedicated cables if possible as it is a better option then an adaptor.
Bill
