There has been much hysterical posting on the benefits of 'star connected plug strips' over the last couple of weeks.
Here's why it is all nonsense.
The usual 4 socket plug strip on a trailing lead has a busbar approach to connect the 4 sockets together. The mains cable is fed into one end of the strip and attached to a bent bit of thick solid wire. This bent bit of wire snakes along the strip from socket to socket connecting the spring clips that grip the plug pins when a plug is inserted. There are 3 bits of bent wire, one for all the Live pins, one for all the Neutral pins and one for all the Earth pins. My 'reference' case in point is the Ikea 'KOPPLA' strip which has 4 sockets and a 1.5M trailing lead. A two pack of these socket strips costs £5.00, so effectively £2.50 each (although they can't be bought separately).
A star connected strip still has a trailing lead, but instead of a busbar (the bent bits of wire), each socket on the strip has its own 3 separate lengths of wire (L,N,E) back to the point that trailing lead enters the strip - where all of the wires are connected together at the 'star point'. Titan audio styx strip has this approach, and costs £150.
Why? Why indeed.
The argument, in that there is one, is that a device plugged in at the end of the strip with a busbar will 'steal current' from the other devices plugged into the strip leading to a reduction in audio quality. This problem is avoided when each socket has its own connection back to the 'star point'. Like all good marketing, there is an element of truth to this. Yes, two devices drawing current along the same cable (or busbar) will lead to a greater voltage drop than if they were separate.
But hang on, don't all the devices plugged into the strip share the same 1.5M trailing lead irrespective of whether they have a busbar or their own 8 inch bit of wire in the strip iteslf? ..and don't they all share the same plug and fuse where the trailing lead plugs into the wall? ... and don't they all share the same ring main back to the fuse board? ...and the cable from there to the local distribution point is shared as well?
So the argument is that replacing 8 inches of shared busbar with 8 inches of unshared cable will dwarf all of the voltage drops of the all the other metres and metres of shared conductors on the circuit. Nonsense.
Now there might just be a case if that 8 inch busbar was really thin and weedy wire, the resistance it introduced was significant in relation to the overall loop resistance and the current draw along the strip was very high. It isnt. Ikea (my reference supplier) are a large international organisation. Their strip is rated at 13A, which means you can plug a 13A load into the strip at any point without it catching fire. I think it is safe to assume that Ikea have adequately tested the strip for this current, and therefore we can assume that the busbar is adequately sized to carry 13A from one end of the strip to the other. As it turns out, I have taken an Ikea strip to bits, and the busbar looks to be far thicker than a 13A load would require. My guess is that for manufacturing reasons, a thicker conductor is preferable - easier to form or easier to install. Also worth pointing out that amplifier and source loads are in the order of a few hundred watts (current flows of 1 amp or so) - any voltage drop on the busbar will be minimal.
So, the question is whether replacing 8 inches of shared thick, busbar with 8 inches of unshared cable, given all the metres and metres of shared paths that the supply current takes is audible.
No is the answer.
Why? Why indeed.
No is the answer.
