I have some PMC TB2+ and 1m high Atacama sand filled stands, together with a PMC XB1 sub (a large beast at 27cm deep, 78cm long and about 28kg). I also have 2 sets of Auralex MoPads.
I’m wondering what the best arrangement is for setting these up in terms of coupling/decouping in a loft room (converted loft in a Victorian terraced house) with a wooden floor which has been carpeted. More specifically:
i) How should the TB2+s be attached to the stands? Just placed on them, or on top of blu tack balls / sorbothane hemispheres / Mopads or something else?
ii) How should the stands be attached to the floor? The spikes are removeable. I suspect I’ll get floor resonance issues spiking through the carpet or, because the carpet (53oz) and underlay (10mm Duralay System 10 underlay) are fairly thick, the spikes may not even reach the wooden floorboards. Might it be worth getting some slabs (pavings slabs/granite tiles, etc) to sit under the stands? Should these rest directly on the carpet, or on MoPads/sorbothane?
iii) How should the sub sit on the floor? It doesn’t have spikes/there’s no option to install them. I could use MoPads to decouple it. Or sit it on granite. Or sub/MoPad/granite/sorbothane … etc….
Minimising vibration transition to the floor would be desirable to help keep family and neighbours happy, so I’m thinking additional mass and decoupling.
Suggestions welcome!
Many thanks in advance.
