- Aug 10, 2019
- 2,556
- 5
- 0
I have all my music on a HP MediaSmart server and want to be able to stream the music to any room in the house. There will probably be 5-6 zones by the time I've finished.
I am planning on having everything hidden away and the music played through ceiling speakers and controlled by remote.
There seems to be two ways to do this but im confused as to which is the best for me.
The easiest would be to get a sonos ZP120 unit for each zone (hidden away) as that has a built in amplified and will wire straight up to the speakers. But at £400 a zone it isnt cheap!
The other option is buy lots of Squeeze box duets and a something like this:
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1873
This would work out cheaper if we assume 6 zones and im guessing the sound quality would be better. But how would I control the volume? Would this be done via the amp or the squeezeboxs? If I need two remotes then this option is out.
Has anybody done anything similar or can advise on waht would be best?
