Speakers?
Daniel 1
24
Monitor speakers vs hifi speakers. Thats the question on my mind if im after a pair of speakers for superior sound say from a computer whats the best in terms of quality? I need advice and help in general regarding differences. Thanks in advance!
CnoEvil
556
14
It all depends on how you like your music presented ie. Very neutral, warts and all; or warmer, smoother and easier on the ear....or maybe somewhere in between.
IMO. Forget about "best" and go with "preferable" (to your taste)....as it's you that have to listen to it, day in and day out.
Daniel 1 said:
differneces bewteen the two monitor speakers and hifi speakers?
Generally, as Cno explained above, with the studio monitor type being the more analytical. However, there are many flavours of each, so you really need to either come to your own view by listening, or be more specific about your needs. These days the two types have come closer in some cases because powered speakers ( with built in amplifiers) are popular for computer stored music playback. And confusingly 'monitor' was often a label attached to hifi speakers to imply better quality, whereas you probably mean the type favoured in studios, which typically come from music equipment shops rather than hifi stores.
davedotco
At the highest level studio monitors and hi-fi speakers are interchangeable, think top end B&W 800s and PMCs.</p><p>At more realistic price levels compromises have to be made, as Cno says, these compromises tend to make hi-fi speakers 'warmer' and 'easier' on the ear, pro monitors 'punchier' and more 'forthright'.
Your preference is pivotal, at the buget end mine is for the latter option, by a fair margin.
If you are looking for something inexpensive that can sound good on your computer then, providing you have a decend soundcard/usb dac then I usually recommend these....
http://www.studiospares.com/studio-monitors/studiospares-sn4a-pair/invt/248050
http://www.studiospares.com/studio-monitors/studiospares-seiwin-5a-pair-powered-monitors/invt/248040
http://www.studiospares.com/studio-monitors/studiospares-seiwin-powered-monitors-pair/invt/248030
The smallest SN4a is fine for a desktop, the bigger models require proper mounting (stands) to give of their best. Inexpensive and ridiculously good value for money.
If you wish to spend more, then there are plenty of options up to about £2-3k, above which my preference begins to swing back to conventional amplifier/speaker combinations.
