speakers positioning problem???
hi my jamos (JA-A102HCS5) are due in tomorrow and i got the task of positioning the speakers around the room correctly ... now this is not a dificult task but i face the proplem that my lcd is positioned in the far right corner of the room and the seating position is in the back left corner when im on the sofa and about 1 meter away from the lcd when playng games so where do i put the center speaker and the sub?
professorhat
992
22
18,895
Centre speaker really needs to go either below or above the TV. Just had a look at the Jamo package and your centre is fairly small so you might be able to fit in your cabinet. If not, you're probably looking at wall mounting it. I was recently looking at this myself, though the wall is flat behind my TV. In your case, possibly something like this would work quite well as it'll hold the Jamo centre speaker and allow you to point it down towards your direction.
Your sub is easier. If you're pushed, it can literally go anywhere. However, to get the best sound, I've heard the ideal way to find the position is to place the sub where you are going to sit, then walk around the room until it sounds best for you. Once you've found that position, that's where you should place your sub!
