John Duncan
plastic penguin said:I don't honestly think knowledge is the main criteria, regardless of budget. How many times over the years have you and I, amongst others, stated "trust your own ears", so on and so forth.
If you're using the car analogy, the same applies. If I had taken any notice of reviews I wouldn't have my Alfa. Yet it has, arguably, been one of the best cars I've owned or even driven. And this has been the crux of my reasoning.
I'm the first to admit I don't have very good technical knowledge, nonetheless I absolutely do know THE SOUND I like - even more pertinent, the sound I DON'T...
Clearly the OP only streams or uses digital sources (think). IMHO, it is about parking his backside in various dealerships and finding the combination that does it for him.
The OP just needs to be strong with dealers and tell them his final budget; room size and acoustics and what type of set-up that suits his needs (integrated, pre/power combo, old fashioned passive kit or active). Also don't pay too much attention to reviews or star ratings, just let the lugholes do the deciding.
That's all very well, but unless you ask somebody all you;ve got is what's on the high street and what you can glean from magazines, which might mean the OP will miss other, less visible options (such as an active setup) or will end up in the local Sony shop.
