Can anyone recommend some speaker stands with integrated cable management? Not essential for me but would appease the other half. If not its the Z1s or Nexus 6s. Many thanks.
daveywavey18:Can anyone recommend some speaker stands with integrated cable management? Not essential for me but would appease the other half. If not its the Z1s or Nexus 6s. Many thanks.
I've got the Atacama SL series speaker stands, no cable management but very good stands though.
i use a bi-wire cable and it looks pretty tidy, but I'm a man, I don't know about such things
Ive got the super dreads no cable managment but cable can be hidden behind the rear as they are quite wide, also superb sounding stand real improvment of bass
Stands Unique speaker stands have cable holes in the base, if that's good enough (although they're not cheap).
You could also consider a cable tidy kit you can pick up from Poundland, which includes self-adhesive brackets in various sizes, velcro straps (I paid about £6 for some of these from WHS a year ago!) and cable ties all for, er, a pound!
