Hi guys.
I just recently bought a pair q acoustics concept 20. Then i inserted the foam you put in the back of the speaker to get more bass? Anyway it got stuck and i couldnt get it out. Then today i tried to hoover the foam piece out. Then what happened is that instead of getting the foam back out, i got pieces of cloth/wool that must have been in the hole in the back of the speaker. I pulled out quite a bit
file:///Users/christiandorn/Desktop/20140129_102359_resized.jpg
Then i tested the speakers, it seems they are fine. But you never know.
Are the speakers destoyed? And if not, how do i get the foam out? 🙂
Christian
Christian
