Just to be clear, of the many problems associated with turntables:
1.If you are standing still and have a rythmic movement of the cones at approximately twice per second, then that is a warp in the record. Most records are warped to some degree.
2. If you jump up and down in your room and the cones move in and out, then that is low frequency feedback - the floor is wobbling the stand which in turn wobbles the turntable which in turn wobbles the platter and arm.
3. Low frequency rumbling sound (hence rumble) is due to the bearings on the turntable, this may produce visible cone movement, but it is much faster than twice per second as is definitely audible.
4. A rythmic hummm at 50Hz that comes and goes once each platter rotation on belt drive turntables where the motor is under the platter is caused by the hole in the platter (to allow belt access) lining up with the pickup and allowing magnetic interference from the motor to effect the pickup.
You can of course have all these problems at once.
