Speaker cable for new speakers
seashell
22
HI,
Just bought some tannoy f4's and marantz pm6002. need some new speaker cable for this but budget is tight (student, no money, etc). don't really want bi-wire, although if you think it would be worth it, be my guest to recommend. but just lookin for some cable around £6 - 7 a metre. as i said budget is tight and can't really go above that.
thanks.
Audiofoolius:This is probably a no-brainer: Chord Carnival Silverscreen (£6/m).
That would certainly do the trick and would even work if you upgrade in the future.
