speaker cable for my monitor audio rs6 av
HI bought my set up at sevenoaks was so sure that they were being truthful about how much to spen on speaker cable??
can any1 help whats the ratio used for cable to speaker price??
Messiah
Ratio I think is down to you and whether you think it is worth it. Do you have a budget??
If you but dearer cable to start with then it may last a few upgrades.
However, if you buy cheaper stuff you may enjoy the benefits of upgrading it at a later date.
THIS is usually recommended in the mag for budget and pricey systems. Seems a good place to start...
