Speaker cable for Marantz PM6005 and B&W 685 S2
mondechristo
Hello,
Any suggestions for speaker cable for my system?
I have a Marantz PM6005 and B&W 685 S2.
A good price for me is up to 10 euro/meter.
Thank you...
mondechristo said:
Hello,
Thank you...
Hi mondechristo
Are you already using speaker cables? If so, what cables are they?
All the best
Rick @ Musicraft
Yes, I use Audioquest FLX-Slip 14/4.
The sound now seems dull, sometimes. Not transparent. The treble are attenuated, not crisp and clear.
MUSICRAFT said:
mondechristo said:
Hello,
Thank you...
Hi mondechristo
All the best
Rick @ Musicraft
MUSICRAFT said:
mondechristo said:
Hello,
Thank you...
Hi mondechristo
All the best
Rick @ Musicraft
If it's really that bad with your Audioquest cables then a simple cable change isn't going to resolve the problem.
You could try starting with a much cheaper cable and see if this improves anything otherwise I be looking at a speaker change.
MUSICRAFT said:
mondechristo said:
Hello,
Thank you...
Hi mondechristo
All the best
Rick @ Musicraft
Agreed.
plastic penguin said:
MUSICRAFT said:
mondechristo said:
Hello,
Thank you...
Hi mondechristo
All the best
Rick @ Musicraft
Agreed.
Tah. My personal opinion only you understand.
MUSICRAFT said:
mondechristo said:
Hello,
Thank you...
Hi mondechristo
All the best
Rick @ Musicraft
Agreed.
And mine.
MUSICRAFT said:
mondechristo said:
Hello,
Thank you...
Hi mondechristo
All the best
Rick @ Musicraft
Hi mondechristo
Is it with the existing cable or has something changed in the system that has lead to the presentation to now seem dull.
Btw, what source/s are you using please?
All the best
Rick @ Musicraft
I think you are right my friend!
I will make a few tests with some cables I will borrow from a shop here in Cyprus where I live.
And maybe a brighter speaker is the next buy for me...*scratch_one-s_head*
MUSICRAFT said:
mondechristo said:
Hello,
Thank you...
Hi mondechristo
All the best
Rick @ Musicraft
Hello,
My sources are my computer, turntable (an old Project with Ortofon Red cartridge) and CD player (SACD Sony) . I tested for a few hours the QED Silver Aniverssary XT. I think there was some difference but I am not sure....
My system is new. The amp and the speakers. The sources are old.
MUSICRAFT said:
mondechristo said:
Hello,
Thank you...
Hi mondechristo
All the best
Rick @ Musicraft
Hi mondechristo
All the best
Rick @ Musicraft
mondechristo said:
Hello,
MUSICRAFT said:
mondechristo said:
Hello,
Thank you...
Hi mondechristo
All the best
Rick @ Musicraft
Hi mondechristo
All the best
Rick @ Musicraft
Hi mondechristo
Thanks for your reply.
Try the following -
Use the tone controls.
Try the Silver XT again.
Basic 79 strand speaker cable.
And contact your dealer/s that you bought the electronics from.
All the best
Rick @ Musicraft
gasolin said:
Here is a review of the B&W 685 s2 with measured frequency response
http://i.nextmedia.com.au/Assets/bw_685_s2_loudspeakers_review_test_lores.pdf
The amp i feel is a bright sounding amp, mabye lacking a bit bass
Have you tried a more punch,powerfull more lively amp with more sparkle?
Might be worth trying without the speaker grilles. And moving further away from any boundary (wall, floor). If brand new, are they definitely wired in phase?
the B&W's come with port plugs (round spunges).
Try them! They slightly de-emphasise the deeper bass, thereby giving impression of slightly faster and 'airier' speaker. It may do the trick. Also invest in proper B&W (or other good ones) stands, the clear up the bass and improve the imaging markedly. Do NOT use the on a shelf, if you care for sound quality.
