reggaedave:
Can someone explain, or direct me to a thread on understanding what spec of speaker would be suitable for my amps?
I have two amps, an audiolab 8000s and a 8000p, and want to bi-amp so trying to work out what actual specs my amp will be producing, to help me choose a speaker!
thanks.dave
It's easy to get tied down with technical information (why I generally keep away from it), I tend to go for whatever sounds right. The one thing, however, is to consider decibels. This will generally dictate the amounts of volume you can acheive from an amplifier. For example, you would probably have less volume with a 100 watt amp connected to a 84-86db speaker, like a Dynaudio or an ATC speaker than you would from a 50 watt amp and a 91-93db speaker like a Monitor Audio.
Stand mounted speakers generally are lower decibels (harder for an amp to drive) than a floorstander which is usually easier drive; this equates to, again generalising, floorstanders sounding better at low levels.
Then you have to consider the sonic character of your amp eg is it warm sounding, is it thin and bright, detailed and open etc. So your Audiolab, from memory, is quite a punchy amp that requires a fairly neutral/warm sounding speakers. So Spendors and PMC I would avoid, because they are so neutral and may sound a little mechanical or clinical.
Hope this helps, my 'grey matter' is going into meltdown. And maybe some else can expand on this.....
Good luck, PP
