Sony STR-DH810 magazine review - Pro Logic IIz comment
Status
Not open for further replies.
mattjax05
230
Hi
I've been racking my brain on the bit where WHF say
"If you opt to use the Pro Logic IIz processing you can switch the surround back channels for front height speakers"
"or you can ditch both and bi-amp the front left and right speakers instead"
Could someone please explain the second quote for me please?
Matt
Andrew Everard
1,878
If you're running a 5.1-channel set-up, you can reassign the surround back channels to work with the front left and right channels to biamplify suitable speakers (ie those designed for biwire/biamp operation)
Im not a expert but I think this might be where you have front 2 x L & R speakers situated like below
FL C FR
SUB
FL> <FR
BL> <BR
mattjax05
230
Andrew Everard:If you're running a 5.1-channel set-up, you can reassign the surround back channels to work with the front left and right channels to biamplify suitable speakers (ie those designed for biwire/biamp operation)
Many thanks Andrew.
Apologies for hi-jacking your thread, but can you tell me which copy of WHF this amp was reviewed in, Thanks in advance.
Status
