I've been using the Sony STR-DA2400ES receiver with Sky HD and blu-ray (Pioneer BDP-FD51) for some time now and still have an infuriating problem getting the sound to synchronise with the TV picture (Sony KDL 46W4500).
I know there's an option to add a delay in the receiver's audio menu of up to 300ms; however, the sync problem isn't always present and, when it is, I'm never sure what to set the delay to. I quite often have to keep pausing viewing to try and correct the sound fault which is very annoying.
Does anyone know if there's some kind of firmware update that might correct this problem permanently?
Thanks.
Thanks.
