Hi everybody can some one give me some advice? I have recently brought the Sony S760 BRP it has been multi region enabled by Sony. However it is only the DVD side which is Multi- region. The Blu will not play region A (locked)blu ray discs as it is set for region B . Can somebody tell me if this can be fixed with a code or does it require a modification inside the player.
Regards
2niceday
Regards
2niceday
