Hi All,
I have a Sony KDL40w4500 and its brilliant - the sound is good on XBOX and also on my sky box and I have the volume level set at 30 or maybe 40-50 if I want it loud.
My problem is that if I want to have the blu ray player at a decent level I have to turn the TV up to 90 which is nearly maxed out and on some films it has to be maxed out (And its still not loud enough)
I have this connected via HDMI.
Why does the sound volume have to be cranked so loud for the Blu ray? have i missed a setting?
its really annoying especially if you forget to turn it down before you switch back to sky!
thanks in advance
thanks in advance
