Sonos vs Airport Express
The_Lhc
1,176
John Duncan said:
To my mind, the Squeezebox isn't portable at all, it's just small. Controlling it is very much a job for your iPhone or Android (iPeng is very nice).
So why give it a touchscreen? Or a screen at all, given it's generally going to be sat on a rack a mile away from the seating position?
omnibeard
27
That is mental.
John Duncan
2,033
27
19,720
Because it makes people go "ooooo" when you show it to them?
omnibeard
27
Do they make a version without the screen - surely that would slash the price? Then it's just controlled on ipad/iphone/android etc.
John Duncan
2,033
27
19,720
They used to, the Duet. But I'm fairly sure that you needed the expensive controller to set one up (though you could then add extra zones for AEX money).
Can still get them:
http://www.amazon.co.uk/dp/B0012K6VIW/?tag=googhydr-21&hvadid=4640233400&hvpos=1t1&hvexid=&hvnetw=g&hvrand=4440970481787573054&hvpone=229.99&hvptwo=&hvqmt=e&ref=pd_sl_7kzdhjul1s_e
omnibeard
27
OK, that looks quite interesting - initially not much cheaper than a Sonos Connect, but you get what looks like a really nice remote. Plus, from that point onwards it's £99 to add a receiver. Presumably its functionality is much like the Sonos?
Only concern would be lack of support if they have stopped making it, but that's pretty small beer I reckon.
Do you know if the Squeezebox Controller app would work with this?
Why have they stopped making this, and why didn't it take off more (or did it)?
omnibeard
27
Looks like you can get it to run Spotify too...
http://forums.slimdevices.com/showthread.php?79706-Announce-Spotify-Premium-Plugin-%28Beta%29
markbbailey
I'm a big fan of the Squeezebox Touch for the very reason that it has a touchscreen. Sometimes, particularly if you've got a multi-room install, you just want to be able to walk up to it and press a button to turn the radio on or knock the volume down a bit. You can also glance over and see what's playing at an instant. If you've always got to locate your phone and load up the relevant app etc it tends to irritate after a while. It's OK in a listening room but if you've got one playing background music in the kitchen, for example, a simple fixed screen device does make life a lot easier.
Cheers, Mark
markbbailey
The Squeezebox Controller App works with all Squeezeboxes going back to the original device.
The problem you'll have with the Receiver units is getting hold of them. You might find a few kicking around on Ebay.
In general they all work very well and you can happily mix all of the different Sbox devices together.
If this helps; I'm a custom installer and have just done a multi-room install with 8 Squeezebox Touch's and 2 receivers. All controlled either via iPads, iPhones, the IR remote or directly on the screen. Customer very happy in a way that he definitely wouldn't be mucking about with AEXs. The Spotify app is excellent too and a big selling point for Sonos and Squeezebox solutions.
markbbailey
Will do but is there a particular format that's required or just a note in the signature?
Thanks, Mark
