*good*. I am getting the Samsung tomorrow too now.nugget2014 said:sorry for the shocking stretched image.
gel said:Do you get a HDMI cable in the box? Ta
Which HDMI cable are you using? Ta.nugget2014 said:gel said:Do you get a HDMI cable in the box? Ta
nope, you dont. and i will take some photos shortly..i dont have my proper camera so only be able to use my phone!
gel said:Which HDMI cable are you using? Ta.
Yep, I got two. Just triple checking they're right.spiny norman said:gel said:Which HDMI cable are you using? Ta.
I thought you'd bought a new HDMI cable or six (against doctor's orders)?
gel said:Yep, I got two. Just triple checking they're right.
gel said:Which HDMI cable are you using? Ta.nugget2014 said:gel said:Do you get a HDMI cable in the box? Ta
Cheers!nugget2014 said:gel said:Which HDMI cable are you using? Ta.nugget2014 said:gel said:Do you get a HDMI cable in the box? Ta
http://www.amazon.co.uk/Cablesson-Basics-Meter-Speed-Ethernet-HDMI-A-Typ...
Yep, they look very clear. Cheers! How are you finding it? Any issues?nugget2014 said:gel said:How about some pictures of your TV?
hope they were adequate.
ellisdj said:Wait until dark you think curtains are ruining those shots
gel said:Yep, they look very clear. Cheers! How are you finding it? Any issues?nugget2014 said:gel said:How about some pictures of your TV?
Takes quite a while, I can't remember how long exactly though, sorry.nugget2014 said:gel do you know how long wowhd take to deliver? seriously considering buying sicario so i dont have to wait. think i need 5-7 days? you ordered from there before then canceled you might have a guess on how long it takes?
gel said:Takes quite a while, I can't remember how long exactly though, sorry.nugget2014 said:gel do you know how long wowhd take to deliver? seriously considering buying sicario so i dont have to wait. think i need 5-7 days? you ordered from there before then canceled you might have a guess on how long it takes?
It was quite a while, but I wasn't really taking much notice.nugget2014 said:gel said:Takes quite a while, I can't remember how long exactly though, sorry.nugget2014 said:gel do you know how long wowhd take to deliver? seriously considering buying sicario so i dont have to wait. think i need 5-7 days? you ordered from there before then canceled you might have a guess on how long it takes?
someone said 11 days, i'll wait for sicario to come out in the UK then..
