Hi All,
I've just moved into a new house and I think it is about time to invest in some entry level equipment. I went through quite a few posts on the forum and a lot of pages and can't seem to get to 'conclusive' conclusion Advice and direction to more sources/revies greatly appriciated.
The constraints are for the setup:
- AV needs to be slim (limits the choice significantly)
- Room size is 3.1x4.5m
- No plans for 5.X or 7.X setup in near future
- Spotify Connect (or AirPlay minimum)
- Small size speakers (will be placed on the shelves)
- Buged around £600 (however less is better, a bit more is acceptable)
Speakers
I'll start with speakers as I find the choice less of a problem:
- Wharfedale Diamond 220 (favourite so far)
- Dali Zensor 1
- Q Acoustics 3020
- Q Acoustics 2020i
- Dali Zensor 3 (??)
There is lot recommendations for Dali Zensor 3 but they stretch the budget and are quite chunky. In fact Diamonds 220s are probably the max size I can go for.
AV Receiver[/b]
Limited space limits the choice in this area. Even less is available taking into account Spotify Connect. I've looked into the following ones:
- Yamaha RX-S600
- Pioneer VSX-S510
- Marantz NR1506 (probably above the budget)
- Marantz NR1606 (above the budget)
What would you recommend? Have anyone here used a combination of the above? Is there anything I've completly missed and should go back to the beginning?
PK
Speakers
- Dali Zensor 1
- Q Acoustics 3020
- Q Acoustics 2020i
AV Receiver[/b]
- Yamaha RX-S600
- Pioneer VSX-S510
PK
