Hi, I use a Technics SL1210 turntable, and have just installed a Ortofon 2m Red. I have made sure the overhang is correct and its fine. I then went about balancing the tone arm so I could then adjust the weight.
I balanced my old cartrdige and stylus absolutely fine, but the new one is casuing me issues. In order to get the arm to "float" i have to move the counter weight pretty much all the way to the front. When I then set weight to "0", it only allows me to add around 1.5g to it, the reccomended is 1.8 but I cannot actually turn it anymore because it is at the very and is basically at the heaviest tracking weight possible.
Could it be the counter weight is wrong light and I need to buy a different one? Apologies in advance for a probably vauge description, but i can supply pictures if needed.
Any help is appreciated, thanks
