SL-1210 set-up advice
Dan_RE
Hi all, newbie here.
Just wondering if I could get some advice on how to get the best out of my SL-1210 with what I have and what additions would be reccomended.
I currently have: 1 x Technics SL-1210, a pair of Alesis M1 Active MKII Studio Monitors and a Focusrite Scarlett 2i2 Audio Interface.
It would be for home use so I am looking to get the best sound out of my records at a reasonable price and have been told that an integrated stereo amplifier would be the best way forward and a DJ mixer would not be suitable. I am also looking to get a hi-fi cartridge for my 1210 and have been told Ortofon 2M is a good cart.
Does anyone have any reccomendations for both an amplifier and cartridge? Looking at spending £300 tops for both.
Also is there any way of linking my audio interface to the 1210 and getting a good sound from it?
Dan
Dan
I could advise but not sure how you'd tie in your active monitors to a stereo amplifier.
Dan_RE
Sorry if I sound stupid but is that not possible? Do I need to get hi-fi speakers?
How else can I get my 1210 and monitors connected?
I am not sure what connections you have on those monitors but you would need something to bring the small output voltage of the cartridge up to line level.
Dan_RE
Such as? They only have XLR inputs.
Dan_RE said:
That's going to be your problem. These are not really designed to take a signal for a turntable.
You can either stick with what you have or sell it on for a passive speaker system with stereo integrated amp.
There are very few phono preamps that have balanced XLR outputs and those that do are not cheap.
Dan_RE
Al ears said:
Dan_RE said:
How much are we talking? Would a cheaper pre-amp without balanced outputs not work at all? Would I be better off getting a passive speaker system with amp?
Sorry about all the questions and thanks for the advice so far!
Dan_RE said:
Al ears said:
Dan_RE said:
In the long run amp and passive speaker would be the way I'd go unless someone else can figure a way.
Cheap preamp would work I guess but you would need a pair of interconnect cables phono plugs to XLR plugs.
I,however, have no idea as to the quality of those monitors you have compared to a cheaper pair of passive standmounts. This could be crucial.
From what I can see they cost about £170 new, is this correct?
If you can find cables then something like the Rega MM mk2 phono preamp and a Shure M97XE cartridge would be good.
MajorFubar
690
7
I thought your speakers had combi-jacks which take either an XLR or 1/4" jacks. But you can't just go rigging them up to the output of a phono pre-amp or they'll blow your wig off: they don't have volume controls. There are input-trimmers in the back, but I'm not sure they're designed to be used as volume controls. Your speakers are supposed to be plugged into a mixer. There are various mixers with dual inputs for turntables, feel free to google.
