Depends on whether you DIY or get someone in.
What's your plan? Is your existing cable easy to replace, can you get to your dish? Do you want a fresh run of cable or do you want to join on to your existing installation?
If you DIY, cable should cost around £2/metre then all you need is connectors at around £3 each.
Cheers,
Cofnchtr.
