Here is the issue - none of the aerial sockets in my flat are hooked up to a central aerial (i.e. no tv reception but for Sky HD box) and I want to put a television in the spare bedroom. Obviously, I can use a scart sender, but the question is --> when I am watching an HD channel (which cannot be sent via scart sender) what (if anything) will be on the second television? Nothing? Or, does the scart socket downgrade the HD material to SD and allow the sender to work?
Alternatively, could I run an aerial cable from the Sky HD box to the television (thus linking the television with the dish) allowing the television to use its own tuner, independent of the Sky Box?
In short, I don't want some ghastly indoor aerial attached to the television!
