Should I use pure direct or stereo for music playback
poldo
66
Hi , i am AV - noob and want to know if I should use pure direct (direct stream) or stereo on my Pio VSX - 920 when I play music from my apple tv (HDMI connected).
poldo
66
Lee H said:
Whichever one sounds best to you. I settled on Stereo in my house.
I use stereo too now, my sub is also turned on and no center, but when I use stream direct (pure direct) the centre is playing as well, :? , i thought pure direct was only 2.0, but I think I am wrong.
CnoEvil
556
14
I can only tell you what happens with "Stereo Direct" on the Arcam, which means all processing is turned off (including bass and treble adjustment), and the sub doesn't work. This gives the cleanest signal possible and sounds best in my case.
poldo
66
I am sorry I was using a wrong setting, Pure direct is stereo only. But I think the subwoofer is on maybe because I set my speakers ( Dali Zenzor 1) at 80 hz?
john1000000boy
240
18,795
Pure Direct is for pure stereo listening, this will switch off all the other circuits and carry the audio straight out. The sub will not work in this setting. My 82 has direct also this is for stereo listening and allows a sub to be used.
poldo
66
Iam sorry but on my vsx 920 the sub is working, i have my speakers on small (80hz). Because I use monitor speakers. But on pure direct my sub is def. playing.
john1000000boy
240
18,795
Will need to check again.. maybe you are right the sub may still be on when playing over hdmi
