- Aug 10, 2019
- 2,556
- 5
- 0
Currently I'm using a Rotel RA-02 that amps a Rotel CD-02 and driving some B&W 602 s3. I'm using an old Yamaha DSP ax-620 for my AV amp which is connected to the RA-02 via the front pre-outs and is then directly connected to some B&W 600 s3 for the surrounds and a B&W LCR60 centre.
I want to upgrade the AV amp but am worried about losing good quality stereo so am unsure whether to take the plunge and buy something like an Onkyo TX SR580 which doesn't have pre-outs and then also sell the Rotel, or keep the Rotel and buy another amp with pre-outs again. In an ideal world one less amp to connect would be perfect.
Cost is an issue hence the Onkyo and I figure that if I upgrade I should get 3D compatible, so any advice greatfully recieved.
I'm also missing a sub so wondering whether to stick to B&W or go for something else? Will probably looking for a second hand unit from ebay.
