Hi everyone,
New to HT and wanting some suggestions on what to implement given my room size.
See here for a photo of my room layout:
View: https://i.imgur.com/JroYv1d.png
Note: On the far RHS, across the 90% of the 4.9m length, are curtains.
Note: Still deciding between sub placement (either SW1 or SW2 in photo above) - SW2 seems 'boomier' (and is slightly louder) than SW1 given its corner placement. SW2 placement wouldn't displace the sofa seat that much, just means the person sitting there can't sit too far on the edge of the sofa (as sub is not a footrest). Open to suggestions too, but those are the most ideal based on my sub crawl measurements.
Current set-up:
This is why I was thinking of skipping the side surrounds (?), and going for 4 overheads or Atmos-enabled speakers.
I'm also open to moving things around, layout wise, if you have any suggestions - albeit TV/TV stand can't be moved, as the stand + speakers can't fit anywhere else in the room.
Also lastly open to any other recommendations/suggestions in general.
Thanks so much for your help!
Current set-up:
- FL/FR: KEF Q750
- C: KEF Q650c
- Subwoofer: SvS SB-2000
- AVR: Yamaha RXV2085
- Not-in-use: B&W DM604 (old and may sell these if can't put them to use)
- Are you meant to get surrounds before overheads? Or it doesn't matter?
- I can't wall mount it to the sides at ear-height on RHS, because there are curtains on the RHS.
- I can't wall mount if to the sides at ear-height on LHS, because the closest wall is too far-left from the setup / Atmos sphere.
- If overheads, should I go with wall-mounted/on-ceiling, in-ceiling or up-firing?
- I was planning to get KEF Q50a's (I'm assuming I could use these in-ceiling)?
- I don't intend to go up-firing as I've heard that's the worst of the 3 options, however, if you suggest my crappy room layout & geometrics only enables me to do this, I agree and it's better than nothing.
- If not, any other suggestions?
