Here’s one for the DIYers - I’m currently modding my Marantz CD63 and wish to clean up the voltage supplies to the various ICs on the board.
Firstly - a lot of people advocate a separate regulated supply for each voltage feed on each of the ICs, Thorsten Loesch on TNT Audio describes excellent results just from fitting chokes and ferrites to the voltage feeds to clean up the noise without going to the lengths of a separate clean supply. Anyone know whether the regs are worth the extra effort/wires in practice?
Secondly I’m wondering the best way exactly to fit the regs, I was thinking a piece of stripboard with a row of LM340T5s on it all supplied from the 10v rail after the transformer and all connected to ground via a 500 ohm resistor as they are very small currents for the regs to be supplying - then wires from each reg to each voltage feed on the board. Any issues with this in practice with noise induced over the length of the wire for instance, or noise generated between the regs?
The other way would be to fit the reg output physically at the voltage supply on the board and have a separate 10v feed to each one - this would be a bit messier and more difficult especially concerning the resistor between the reg and ground, but doable, easier if you build your own regs but I wasn’t wanting to go to those lengths.
