radiorog said:Vladimir said:I'd gladly use that one. Just make sure it is terminated with spades or banana plugs because 6mm bare wire will not fit in your standard speaker terminals (amp or speaker side).
Cool, but now we are getting into a whole load of unknowns for me as I have always had bare wire into terminals. Could I ask what grade of plugs do I need, where is a good place to get them,is there a recommended technique for applying plugs (for best sound), and will my local shop be a good place to do all this? Cheers
In the link you sent the retailer does cable termination per request. Scroll down the page.
Banana plugs are easy to live with and spades are better at contact and if you don't have much space behind the amp. Make sure you can fit spades on the speaker and amp terminals if you like that option. Banana plugs will most certanly work on any.
