radiorog said:That's great burnsie, cheers! I have written down your email address so if you want to delete it now you can.
Vlad, are you serious about the cables or just stiring ;-) I think we will be listening to both my dyns and I will be interested to hear burnsie's harbeths.
Vladimir said:radiorog said:That's great burnsie, cheers! I have written down your email address so if you want to delete it now you can.
I'm serious about the cables. I'd use really thick ones for this comparison. 4mm and up.
radiorog said:Vladimir said:radiorog said:That's great burnsie, cheers! I have written down your email address so if you want to delete it now you can.
Vlad, are you serious about the cables or just stiring ;-) I think we will be listening to both my dyns and I will be interested to hear burnsie's harbeths.?
Well, I have chord silver screen. I'm not sure how thick it is, but it doesn't look 4mm. Any idea how thick these are? I'm not sure what burnsie has.
radiorog said:Well, looks like I have my next upgrade! Which cable might you recommend? I have seen this http://www.ebay.co.uk/itm/Van-Damme-Black-Series-6mm-Speaker-Cable-Sold-By-The-Metre-Unterminated/381140772301?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3D56b16c460d6b43419a128b0429a4e9d2%26pid%3D100338%26rk%3D2%26rkt%3D27%26sd%3D151342962930
Does this look OK? Do you trust the seller? (Seems legit to me as they appear to have a shop).
I only need 4m so won't be to huge an outlay.
Andrewjvt said:radiorog said:Well, looks like I have my next upgrade! Which cable might you recommend? I have seen this http://www.ebay.co.uk/itm/Van-Damme-Black-Series-6mm-Speaker-Cable-Sold-By-The-Metre-Unterminated/381140772301?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3D56b16c460d6b43419a128b0429a4e9d2%26pid%3D100338%26rk%3D2%26rkt%3D27%26sd%3D151342962930
Fit it to your existing set up first. I. Sure you will notice an improvement
radiorog said:Andrewjvt said:radiorog said:Well, looks like I have my next upgrade! Which cable might you recommend? I have seen this http://www.ebay.co.uk/itm/Van-Damme-Black-Series-6mm-Speaker-Cable-Sold-By-The-Metre-Unterminated/381140772301?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3D56b16c460d6b43419a128b0429a4e9d2%26pid%3D100338%26rk%3D2%26rkt%3D27%26sd%3D151342962930
My existing setup? ;-) that was the plan. I'm only wanting to hear the abrehamsen out of curiosity, I am very happy with the k3, I don't need to upgrade. The Abe would have to be a huge step up to force me to change anything.
Andrewjvt said:radiorog said:Andrewjvt said:radiorog said:Well, looks like I have my next upgrade! Which cable might you recommend? I have seen this http://www.ebay.co.uk/itm/Van-Damme-Black-Series-6mm-Speaker-Cable-Sold-By-The-Metre-Unterminated/381140772301?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3D56b16c460d6b43419a128b0429a4e9d2%26pid%3D100338%26rk%3D2%26rkt%3D27%26sd%3D151342962930
Compared the caspian to the abe and both much preferred the abe so if your happy i wouldnt bother as it might give you an unwanted bug to upgrade that you dont need.
+ 1 ..... let us all know what speakers , cables , cd player , music you 2 will be useing and let us know what you think of both ampstonky said:that sounds like it would be very interesting. Please be sure to feed back.
tonky
Vladimir said:I'd gladly use that one. Just make sure it is terminated with spades or banana plugs because 6mm bare wire will not fit in your standard speaker terminals (amp or speaker side).
Blacksabbath25 said:+ 1 ..... let us all know what speakers , cables , cd player , music you 2 will be useing and let us know what you think of both ampstonky said:that sounds like it would be very interesting. Please be sure to feed back.
tonky
