Schiit Magni 3 channel unbalance
angelmf2704
96
16
545
Hello, I have been trying the HD600 for the last month. I'm really surprised by the sound of these cans. When I was buying this headphone, I read a lot about getting a dedicated AMP. So I bought Schiit Magni 3 and paired it with a Hiby FC1. I have noticed that the left channel is louder than the right channel when using the Magni, but when I only use the Hiby FC1 it sounds balanced. I don't have warranty or a return option, what can I do to fix this?
P.D I use Qobuz desktop app if that matters.
Thanks in advance
If you haven't already done it, try switching the Magni to low gain so that its volume control needs to be further up for normal listening (preferably at least its 10 o'clock position).
See if that cures the imbalance.
The problem is that even in low gain mode, It's too loud for my ears. I thinI could decrease the software volume in Qobuz and increase on the magni. I don't want to make it worse.
Yes, that's the problem. You need to reduce the signal level going into the Magni.
Once you can comfortably use the Magni volume control at (or past) the 10 o'clock position, your channel imbalance will (almost certainly) be cured.
Hello
The issue here is not likely to be the Magni 3+ AMP, but what you are trying to do.
The Hiby FC1 is a portable headphone DAC/AMP:
It is already decoding and amplifing the signal from your source device. It is not a descrete DAC.
If you want to get the best out of the Magni 3, you should be pairing it with a descrete DAC. You will be doing a dis-service to the Magni connecting up like you will be via a 3.5mm Jack to RCA. It's only going to amplify what ever sound is already being 'amplified' already by the Hiby and is not designed to be used in this way.
Hello
Of course he's not using the optimum source Jimmy, I agree with that.
But you must agree that if he reduces the input level to the Magni then, out of the tracking error danger zone, his imbalance will not be an issue - and imbalance is after all the issue he has complained of.
We'll see. Easy enough for him to try it.
Edit: There's a chance he could turn the Hiby down into its own danger zone 🙂 - so yes, totally agree he should be using a fixed level DAC into the Magni. (Although, if his Magni has a really dodgy pot, then even that wouldn't help the imbalance).
Edit: Of course, there's a chance he could turn the Hiby down into its own danger zone - so yes, totally agree he should be using a fixed level DAC into the Magni. (Although, if his Magni has a really dodgy pot, then even that wouldn't help the imbalance).
True, but equally it could be a cable or connection issue from the adapter cable being used, or an inbalance in the Hiby that's just being exacerbated as soon as the Magni is put on the end. To rule it out, testing would be looking like:
1. Try a different adapter cable or test the same cable into a different device if possible
2. Check for any inbalance in Software/Windows (if applicable)
3. Test with a descrete DAC in front of it (see if a friend has one or if can test at maybe a HiFi store?)
If the Pot is truly dodgy, then it would then need an RMA at that point.
Yes, but he's got no warranty or return option apparently.
(I bet he's only just off minimum on the Magni v/c at the moment, so it's got no chance).
Urrgh.......well that certainly throws a spanner in the works if it's the pot.
Testing will confirm for sure if that is the problem.
Hello, in the future I will upgrade to a desktop dac. I don't live in the US or Europe so getting is audio gear is not that easy. I was thinking the Schiit modi, but I don't want more troubles in my setup.
Hello, about the reducing the input level. What's the best option, reducing the Qobuz software volume or the Hiby FC1 volume?
The Modi is the obvious choice for you, the sooner you can get it, the better.
For now, leave full software and reduce the FC1 volume.....by as much as it takes to get the Magni volume control well above its lowest region.
