Hello,
Was hoping someone could offer a quick bit of advice...
I'm looking for a 32 inch TV. Used mainly for SD freeview TV and high def games on the xbox 360.
Both of these are £300 on Amazon.
Would you recommend one over the other?? Is there anything else I should consider?
http://www.amazon.co.uk/Samsung-LE32C530-32-inch-Widescreen-Freeview/dp/B003EEM1M4/ref=sr_1_1?ie=UTF8&qid=1293557479&sr=8-1
http://www.amazon.co.uk/Sony-KDL32EX403U-Widescreen-Internet-Freeview/dp/B003BVI49E/ref=br_lf_m_1000477983_1_2_ttl?ie=UTF8&m=A3P5ROKL5A1OLE&s=electronics&pf_rd_p=223653227&pf_rd_s=center-3&pf_rd_t=1401&pf_rd_i=1000477983&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=1TBADTA9F0WPBX1CCQN9
Many Thanks!
P.S Does anyone know if you can watch high def iplayer straight on the sony TV?
Many Thanks!
