Does anyone know if it is ok to use russ andrews superior mains ring, witch has 16 woven hyper-pure copper conductors insulated with teflon and a central earth core, to make up your own mains leads
Jim Highfield:I think it would be better not to bother, mainly from a safety angle but also because it's pointless.
But surely the Russ Andrews website wouldn't lie?
Russ Andrews web site:
Russ Andrews Superior Ring Main cable is our best cable for the job, using the highest purity copper and insulation. Your system will sound sweeter and more natural, rhythmic and musical.
I was thinking the russ andrews mains ring, seems to be the exact make up of the russ andrews reference powerkord wich also has 16 woven hyper-pure copper conductors insulated with teflon at 125 pound. Thus thinking i could make up the rference powerkord on the cheap, what do you think.
Dougie 2:I was thinking the russ andrews mains ring, seems to be the exact make up of the russ andrews reference powerkord wich also has 16 woven hyper-pure copper conductors insulated with teflon at 125 pound. Thus thinking i could make up the rference powerkord on the cheap, what do you think.
Give it a try. Then blind test it, and post your results. If you burn your house down, I didn't say that.
